Voltage Drop
  • 3
littlebeep3
4
NC
I have a 2008 accord, running an aftermarket head unit, hifonics amp, and 2 subs. About a week ago i was riding down the road after turning the amp up, possibly too high, and my subs quit working. Sometimes they work, most times, not. I'm not getting full voltage to my remote wire and i've tried rewiring and i get full power to the amp but it slowly fades. the amp is getting power, just not much at all. the blue lights on top are very dim, but the subs don't work at all now and my knob is getting no power. help please!
agreed, sounds like a ground issue.
an amplifier ground wire should have a properly sized ring terminal that is solidly bolted to the vehicle floor. paint should be sanded away from the grounding location. you should be able to attempt to wiggle the ground wire ring terminal with no movement. any deviation from this is a poor ground and will cause a low voltage reading.
Upgrade just arrived...SHCA Black friday sale for the win. Even more voltage drop, here I come.
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
littlebeep3
littlebeep3
NC
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
