SOLD Two sony es amps (4 ch+2 ch) 200+shipping
  • 3
tyroneshoes
NJ
Ok, I need these outta here and I'm willing to take a loss. This includes the 4 channel xm-5046 and the xm-4026
You all have seen this one. Suprised I'm having such a hard time moving it. Fused at 60 amps. Classy aesthetics as well. Beefy internals. Some pics:
47b7d629b3127cceb955065129fe00000026108QcMmTRq4aa
47b7d629b3127cceb9550650a8cf00000026108QcMmTRq4aa
47b7d629b3127cceb955065729f800000026108QcMmTRq4aa
Output Power (20Hz ~ 20kHz):
4 x 50W @ 4 ohms (12.5V - 0.04% THD)
4 x 60W @ 4 ohms (14.4V - 0.04% THD)
4 x 75W @ 2 or 1 ohm (12.5V - 0.1% THD)
4 x 90W @ 2 or 1 ohm (14.4V - 0.1% THD)
2 x 150W @ 4 ohms bridged (12.5V - 0.1% THD)
2 x 180W @ 4 ohms bridged (14.4V - 0.1% THD)
2 x 250W @ 2 ohms bridged (12.5V - 0.1% THD)
2 x 280W @ 2 ohms bridged (14.4V - 0.1% THD)
THD:
Freq. Response: 5Hz ~ 100kHz (+0/-3 dB)
Fuse: 2 x 30A
Dimensions: 17" x 7.25" x 2.5" (43cm x 18.1cm x 6.2cm)
Weight: 6.8 lbs. (3.1 kg.)
Aside from this amp, you also get this xm-4026
Stereo Mode: 40 watts rms x 2 @ 4ohms /70 watts rms x 2 @ 2ohms / 80 watts rms x2 @ 1ohm
Bridge Mode: 80 watts rms x1 @ 4 ohms / 120 watts rms x1 @ 2ohms
20 amp fuse
Unfortunately I only have one of the end caps. Very small foot print and would make an excellent tweeter amp to go with the 4 channel.
200 plus shipping. In case you dont know, this here is a steal.
847
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
975
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
tyroneshoes
tyroneshoes
NJ
tyroneshoes
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
