Two DVC 4ohm subs, separate boxes, 1 ohm?
  • 2
Rob93
Hey all, I am interested in installing two separate, mirrored, custom subwoofer boxes.
I want to have a final load of 1ohm.
I have two DVC 4ohm subs
I’d prefer to use both voice coils.
I saw a diagram online that is basically the picture I drafted up to help visualize, that is supposed to be a total load of 1ohm (if that picture was even right?) What can I do differently to use both coils?
Thanks in advance for any advice
Wire each sub like this, and then each 2 ohm sub will give you a final load of 1 ohm as long as your using 1 amp
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
486
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Rob93
Rob93
Philadelphia, PA
Dafaseles
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
