Twister f4 560
  • 4
Your going to have to read it a bit, looks like there are input options for stereo /mono too. I would think that in mono mode, it sums the two RCA inputs.
That picture you posted illustrates a tri-mode operation, not what you are going to be doing. Wire up the full range speakers to the 1-4 L/R channels as indicated in the manual and then for numbers 5-6, wire it to the sub like this. Subs + to the number 5 L+ and subs - the number 8 R-
Seems nore simple like this thanks
This is a feature that uses passive crossover components. On the full ranges you use bass blocking capacitors, and high frequency blocking inductor coils on the sub. It is just like using 2 or 3 way components with a passive crossover network.
You still have to follow the Ohms specifications. 2 Ohms lowest per full range and 4 Ohms for a bridged sub.
View attachment 58617View attachment 58620
Ok thanks I'll bridge the sub at first then think about if I'll connect the rear full ranges aswell
That tri-mode reminds me of the Coustic Power Logic amps; they have that feature.
I ran a JBL GTQ400 with two sealed 4ohm Kicker StillWater 10s with a set of Fultron tweeters and a pair of JBL GTQ 6x9s. Sounded great in a single cab 87 Toyo truck to start out with. Never had any issues
The white ones with purple silkscreen. I liked the look of those amps. Never got to hear them, no one I knew had them. As an amp hoar.... collector, I still have the 360s, 1-260, and 1-160. I now feel like hearing them.
Tri-mode is an outdated option for most. It allowed people with decent 2 channel amplifiers to run sub/sat configurations without using an additional amplifier.
Id run them for a bit man. try enjoy them. I swapp alot. usually like every 3-4 months.
yes the white JBL and even the Concord GTQ series. I still have a GTS 600 left and I think a 300. I collected all those JBL GTQ and Concord amps. Im pretty sure I had well over 60 of them. I finally lost count on how many amplifiers I have now, and rest of the car audio gear? Its an addiction with me?? LOL. got to have it.
hi all, thanks for allowing me to join your site. im installing 2 soundstream tx4.560 4 channel amps, but i want to run them as 2 channel...
Malta
