Tri-Sub Box Design
  • 6
Reddish Neck
TD's & Beer
I'm working on a new box design for 2x10" subs and 1x12" sub. This is just a mock-up of what it will look like so far. The black shapes are vents. Let me know what you think.
i'd be real carful doing a design like this. make sure the box is built properly. this includes sealing off each woofer into their own chamber, running seperate amp for each woofer (at least the two tens from the one twelve), and make sure the port is designed correctly.
---------- Post added at 02:23 PM ---------- Previous post was at 02:22 PM ----------
atleast his name matches is condition.....
dont mix and match subs period....wether ur just trolling....or being serious
Wow, for one I'm not the one trolling. And I'm fairly new to car audio but I want to come up with something different. The whole reason I posted it was to get peoples opinion on whether it's a good idea. Obviously it's not the best idea so calm down.
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
253
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
344
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
493
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
603
Reddish Neck
TD's & Beer
Reddish Neck
Racine, WI
Falcons
1aespinoza
    May 23, 2024
Doxquzme
    May 22, 2024
