too much power? need upgrades?
TupacThaDon1971
sandusky
alright i have two basic jl w3 12s, single 2 ohm so going to run at 1.....found a deal possibly on an audiobahn a18001dt  that does 1800 at 1 ohm...i'm looking to be at like 1000-1200 for these subs, my question is, could i run this amp without supplying too much power to the subs by keeping the gain basically off, and if so, would i be able to run this amp on a simple 0 gauge run with the big 3 upgrade and nothing else???
What do you mean basic? Which model are they because they have like 4 revisions for that particular model. You can "limit" an amps output by setting the gain properly. I would pass on the amp as I'm not too fond of them and the output power might be inflated.
Lets say those subs are 300 rms....set the gain from DMM to 17.32
Or lets say the subs are 400rms set the gain to 20.00 or close to it on the DMM.
They're the newer v3 ones which say they say are 100-500 rms......so sorta aiming at like 1200 Max to them so the amp being inflated would be alright for my case now....but as far as the power goes, would my charging system be sufficient for it?
your master head unit volume, subwoofer level and amplifer gain control all control how much power goes to your subs. Its always better and safer to have too much power rather than not enough to keep the signal clean while getting the output you need.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
TupacThaDon1971
TupacThaDon1971
sandusky
Jeffdachef
    May 16, 2024
    May 16, 2024
