To upgrade, or not to upgrade?
  • 4
tdub93
I have a stock 98 Dodge Intrepid that I just got and plan on putting all my stereo equipment in from my old car. What I would be running is a 320w speaker amp, along with a 2000w amp wired at 2ohms pushing 1300w to power my subs. My question is, is it a must to upgrade to a HO alternator and aftermarket deep cycle battery or will beefy 0/1 gauge wires and a capacitor get me by?
Sorry if I'm breaking any unwritten rules, first post, new to the forum!
Thanks for your input!
If you are wanting to actually achieve these power outputs, it will not be possible with just a wire upgrade and capacitor will not get it. You have to start at the source of the power and that would be your alternator. I would go ahead and change out your alt, get a decent AMG battery and do the Big 3 for ~2.5K. Hope that was helpful.
depends on the type of equipment your using, we need to know how legit the power your using is. if its true 1300 i dont think its mandatory to have a alt, a good batt and a nice run of wire should suffice. 1/0
If you don't push your system full tilt constantly or for really long periods at a time, a good run of 1/0 & Do your big 3 while you're at it; is all you really need for now, a descent AGM batt is never hurts, but you can get by for now w/o as long as your current batt is healthy //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Don't ever waste your money on a cap - they are absolutely pointless for car audio
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
562
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
693
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
822
tdub93
tdub93
Champaign, IL
NIHL8ION
    May 31, 2024
    May 24, 2024
