This girl needs help! ((Factory radio to touch screen after market))
  • 4
14lh11372
Okay so I have a 2003 Impala 3.4L. I recently purchased a plye touch screen radio setup. I have all the wire hook ups and such. The wiring from the aftermarket is corrected labeled but how do I hook them up to my impala wires? They do not match color codes I looked that up. It says I need to connect the "parking" wire on my aftermarket to the -B on my impala in order for the screen to work, what is the color of the -B wire on my impala? I need help!
Thanks,
Haley
Your going to need something like this link and the wire that needs to get connected to the parking is the 2nd ground wire. Most screen headunits has a 2nd ground wire that connected to the hand brake so when you put the hand break down the screen shows. It's mostly a safety so the screen don't remain on when the car is parked and your inside but you can just ground that one off direct to something metal behind where the head unit sits. You shouldn't double check my advice before any actions, good luck //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sounds like you need a radio harness. It connects to your factory radio harness and gives you wires to connect with your aftermarket. Can also look up the12volt.com for vehicle specific wire colors
Okay so I have a 2003 Impala 3.4L. I recently purchased a plye touch screen radio setup. I have all the wire hook ups and such. The wiring from the aftermarket is corrected labeled but how do I hook them up to my impala wires? They do not match color codes I looked that up. It says I need to connect the "parking" wire on my aftermarket to the -B on my impala in order for the screen to work, what is the color of the -B wire on my impala? I need help! Thanks,
Haley
I just went through the same install...
You will want the following to help make it easy.
Amazon.com: Metra Axxess Non-Amplified/Non-OnStar Interface Harness for Select 2000-2005 GM Vehicles: Car Electronics
Amazon.com: Scosche Automotive Wire Harness -1988-up GM Micro/Delco Antenna Adapter: Car Electronics
I was able to use the instructions provided with the HU and with the Metra harness. The colors matches the HU as they should. If you run into issues take a few pictures or list the harness you have and the "leftover" wires that you are confused about.
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
972
14lh11372
14lh11372
Alexandria, mn
dhall615
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
