The next dumb question
  • 2
So I have another borderline retard question for a car audio guru. So I hear that using non-matching subwoofers (2 different subs), can cause odd problems. Also hear that its better to use 1 amp to 2 subs vs 2 amps to 2 subs.
Questions:
What exactly is the main issue with pairing non-matching subwoofers?
What about an alpine 5th gen type r(1000wrms) and a 4th gen type x(1000wrms)?
What about 2 identical amps?
The thing is, a guy locally is selling a used type X and the price is right. Already have a type r and they have similar power handling and considering they are same brand name, thought maybe they would pair together reasonably well.
Thanks in advance for answering an idiot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Also I'd value the input of someone who has tried this type of thing.
Mismatching subs can be a problem if one sub is stronger than the other(s). The pressure off the back of the cone can actually cancel out the other subs movement causing it to reduce output considerably.
In your case you could probably be alright but the best thing to do if you are going to run them is separate them into two separate but identical boxes.
Running two amps instead of one isnt a bad thing. If each sub is a dual 2 ohm then you can wire each one to an amp at 1 ohm to get max power from the amps. If they are dual 4 ohm then you should just wire them together to one amp for a 1 ohm final load.
If you do use two amps you need to either gain match them or bridge them to run it properly.
From what I can see, that cable will not work at all, as the A&K only has balanced and unbalanced analog outputs. No digital available. No...
964
Too little power won't smoke a sub...a clipped to hell signal from not setting the gain right can though...
27
1k is iabout the upper end running off stock electrical...and if you don't have the available power for your amp then it really won't hit rated...
12
I know i know another one of these dang threads. I sold my 2 12" xv3 sundowns, they hit good and plenty loud but not enough spl for me. Im going...
Fi 4.12's. Any thoughts? SEMA Showdown this weekend. This is a daily driver. 180+.
Wick3D
Wick3D
Louisville
BSchrowang
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
