Taramps
  • 4
I run a 800x4 bridged to the mids and highs in my daily driver. I would buy it again. Plenty of power. Like all Taramps, the gain pots feel cheap. But you set them once and leave them alone.
I have had quite a few. They are little monsters for how small they are and I was happy with them. The downsides are they are more suited for active crossovers. The onboard crossovers are very limited on the amps themselves. They only have two pots which is for gain on channel 1/2 and 3/4 and alot of people don't understand the shared negative/positive terminal they use.
I'll say the same thing I always do about taramps crossovers. Don't use them unless you absolutely have too. Preferably run some kind of processing or whatnot so you can just avoid having to set the crossovers on the amp.
The amps are otherwise great in my experience, plenty of power and small footprint.
Matt
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
The ds has more power...it's rated at 12.6v and the ts at 13.8v... I had the the ts400x4 though and it a good little amp
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
mat3833
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
