Taramps Smart Bass 3k or Bass 5k for AB Hawk 1244s
Also if tuned properly I shouldn't need to worry about blowing the speakers huh. Ig I am leaning towards the 5k then.
If you tune properly .. you should NOT have any issues as long as you meet the Sub Ohm load configuration and the amplifiers ohm stability with the power supply for the demand.
Grab a 5 k cheaper than the SD amp
The Sundown is actually stronger at two ohms and is built with Korean parts and doesn't require two runs of 1/0. $2 cheaper 😂. Now add the $100 for the extra run of 1/0 power and ground. To each his own.
Hmm, thank you for all this great information. Now I wonder if I go with a sundown or the taramps 5k 😂💀. Good to know the 3k is out of the question though. This helps!
Oh boy do I know too much about that... 20 years as Type 1. :poop:
13
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Buck is NOT designing boxes atm and hasn't for many months now. And will not be doing any designing for the long term due to his health joe.
20
4K
You don't understand understand brazilian amps and how finicky they can be about voltage...everything you just said nonsense
13
NobleClo
CarAudio.com Newbie
NobleClo
Florida
Bobbytwonames
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
