Tape player headunit..adding subs?
  • 4
Phlipbak
CA Enthusiast
Ok guys, sorry to keep adding threads.. My buddy has a 2000 Mercedes CLK with a stock tape player headunit, no cd player, and they don't make wiring harnesses for these or headunit dash install kits..
so.. he still wants to install subs lol.. and has already bought everything..
Using a Line Output Converter, would subs work fine with the signal from a tape player?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Remember those casette adapters that you put in the tape deck, that's like a cassette with a wire coming off it to your cd walkman....
That's what he needs
And how would I hook up that lc6i..
Like would I splice the rear speaker wire into the rear inputs on the lc6i and run RCA's from the sub out to the amp or would I have to splice the rear speaker wire into the sub input..? And would I turn down the output knob on the converter or what?
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
538
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
Phlipbak
CA Enthusiast
Phlipbak
Dothan, AL; Nashville, TN
Phlipbak
maylar
    Jun 2, 2024
    Jun 1, 2024
