Switching radios - CAN vs switched Power
  • 1
h0tfus3
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio.
I have a Fiat Punto Sound (2006) that came with a Blaupunkt MP3/CD radio and, because it broke, I've decided to buy and mount a Sony dsx-a210ui.
Everything was going fine and I was able to switch the connectors to the right place. Radio is working fine but it does not "listen" to the car key position.
The old Blaupunkt radio had two connectors (CAN High and CAN Low) and the new Sony has a switched power connector instead.
I've tried to research a bit about what CAN is, and it doesn't seem related to the switched power connector in any ways, so I didn't wire those up.
However, I did come across something in the old manual that said that the ACC position only worked with CAN!?!? So, I'm really confused.
Is there any way for me to connect the switched power in the new radio so that it shuts down when I turn off the car ignition? Or do I need new wiring for that?
Thanks for the help in advance.
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
668
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
982
Yea, I'm running 6S2P. 12 cells total, 2 banks of 6. Resting voltage isn't as big of a concern, it's more about charging voltage. LTO shouldn't be...
10
If you are metering outside the vehicle then I get it. The other option is the M1 has tons of slack on the cable. You can always stick it to the...
135
11K
yeah, it'll be hot but off. Just like your tv when it's plugged in.
h0tfus3
h0tfus3
Lisbon, Portugal
h0tfus3
    May 18, 2024
    May 16, 2024
