Subs, box, or amp?
  • 2
First box I built was sealed for 2 e 15s with a rf p1000x2, next I built 7 cubes net @ 32hz, it was 5 inches too deep to fall inside trunk so no go, next I built 4 cubes net @ 32hz and put 2 kicker Cvr in on the rf p1000x2, ugh it's the same db as the sealed 15s which is 124-125db, the e 15s sounded a lil deeper and cleaner tho, I would like to be in the 140s, I can only go sealed 15s or ported 12s the way the trunk built. So do I go to SA 15s sealed on 2 cab 1600.1 amps or 2 SA 12s ported 4 cu ft net @ 32hz on 2 cab 1600.1? I'd feed each sub 1500w
Yea gains will be down, just wondering about the longevity of the 1600s ($400) compared to skar 3500 ($629) , any idea why it's staying under 130db With the last 2 setups?
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
432
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
9
SLAB153
SLAB153
Lafayette, LA
SLAB153
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
