Sub wiring help
  • 2
djwalmart
ATL
I have a single lanzar maxst 12 sub and i am trying to figure out how to wire it to my amp with the duel set of connecters on the rear of the sub. and which way it needs to be hooked to the amp it is a 400 watt 2-4 channel bridgeable amp
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
A little DAP will do ya, drill, feed & seal, done.
634
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
djwalmart
djwalmart
ATL
djwalmart
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
