Sub watts at this many ohms wired to this many???
  • 3
saucy.ass.bo.510
CarAudio.com Newbie
Ok so me and my buddy are stuck. We have 3 subs all SVC 2ohm 500 watts rms. And the only final impedance these subs can handle will be to wire them up to a 6 ohm load. What would the watts be if wired at 6 ohms per sub? And the total watts all together? And how do i figure out the wattage needed for the amplifier we need to buy still? Well most amps are rated at 4 ohms, so how would i calculate that to 6 ohms is what i mean
Is it possible to get a 4 channel amp and hook each sub to its own channel? And just not use the 4th channel? Or would we have to trade our 2 ohm subs in for the 4 ohm subs and have to bridge the amplifier? Would this be better for the subs and amp?
Will this work with any 4 channel amp?
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
475
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
503
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
608
saucy.ass.bo.510
CarAudio.com Newbie
saucy.ass.bo.510
Bay area
