sub magnet through the back of the enclosure?
  • 3
bhom920
17
NJ
So I have a old infinity basslink with a blown amp that i'd like to repurpose into a "free" low profile setup utilizing the old driver and also the passive radiator since i really enjoyed the sound. I calculated that the inside of the old infinity enclosure was to be about .45 cubic ft. I plan to build a box that is 24.5x11x4.74 using 3/4 MDF (scraps that i had left over from another project). The biggest problem i am having is the fact that the sub needs about 4.7" of underside mounting depth.
Now i apologize if this is a really stupid idea and i know most of you will say to just buy a slim mount sub, but what are your thoughts about cutting a hole on the opposite side of the box so that magnet can now sit out of the box and then siliconing the magnet to create the seal around the edges of the box?
Id seal the bolt hole up with Silicone and maybe look into placing some Poly Fill inside the Plastic enclosure and mount the new sub and run it...
187
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
533
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
566
bhom920
bhom920
NJ
adulbrich
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
