static noise in all speakers PLEASE READ!
  • 2
bdunk2323
ok so bare with me, i have a 2001 chevy malibu ls with kicker zx450.2 for my mids and highs, kicker dx1000.1 for subs, kenwood excelon deck, kicker 6.5 and 6x9 (both cs), two batteries, 0 gauge kicker wire. i have always had this problem through several setups, used to have whine also but i cleaned up all connections to perfection and no more whine. i still have the static ticking popping noise (engine on or off)
static goes away when i plug my ipod directly into the amp so speaker wire and grounds are not the problem
static stays when i plug in any other kenwood deck even tried grounding the chassis of the deck
just spent $50 on tsunami rcas
btw my deck stays on even when i turn off my car and open the door then goes off after 15 minutes from the timer delay
static stays when i unplug second battery
my computer runs through my deck, i needed a $120 box wired into the deck wiring (was done professionally) when i first got the deck everything was fine but then for one day my turn signals wouldnt come on the dash and ive had a whole crapload of electrical issues since, such as door ajar switch on continuously, well hell i could go into a whole bunch of stuff but would it be possible for the computer to be making that static noise? if so then how would i go about fixing that? new computer? please let someone have some experience with this
Do you know anything about them? How they work? I know it has the battery wire going in it and the serial bus wire but idk the others theres only like 4 or 5
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
905
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Sounds like HU, but I'd try hooking up the speakers to a different source as a troubleshooting step. The professional installer who charged for...
bdunk2323
bdunk2323
indy, in
bdunk2323
