Static Hissing
  • 1
sriley1556
CarAudio.com Newbie
Installed a JVC KW-M750BT in a 2013 Mazda CX-5. Used all appropriate wire harness adapters and steering wheel control adapters. All functions work on all sources but there is a constant static/hissing heats from the speakers no matter what source is being used. It does not increase in volume at all and of course if the volume is up it can’t be heard but if volume is lower or when using th phone feature it is quite noticeable. I’ve tried installing a filter but that does not help at all.
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
905
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Sounds like HU, but I'd try hooking up the speakers to a different source as a troubleshooting step. The professional installer who charged for...
sriley1556
CarAudio.com Newbie
sriley1556
North Carolina
sriley1556
