Starting off new again!
  • 2
WinC101
Bonaire
So yeaa.. just posted a thread about a kicker amp. i was about going Full Kicker on my setup since im a big Kicker fan. zx2500, Solo X 12. but anyways..amp didnt work out good. and im really tired of this ****. im deciding on letting my kicker setup down..not completely. zx650.4 and Kicker 0 gauge wires are coming brand new, so i WILL be keeping that for sure. cause kicker wires are the best. 650.4 is very good for mids and highs. so practically i'll need a new AMP for sub, and possibly new Sub. Nowadays, there's sooooo much good brands. Everyday i see brands like Sundown, DC, Crescendo(amp) and i really want to try something new. Maybe introduce some of those brands on my island. So budget will be around 1k for amp and sub. looking for @ 2500 RMS. i have in mind DC LVL 5 sub and a DC 3.5K amp?????
Instead of buying all new gear that you don't know how to use, why don't you learn how to properly set up your current gear? You have a good amp, at most you would want a new sub that you can wire to 2 ohms to use the full power of the amp. Don't forget about electrical upgrades either.
Yes man, Solo X 12 will be here in 2 weeks. its D4 so it will be wired at 2 ohm. already got the big 3 upgrade. upgraded battery. not the best but its good. Stock alt! So i guess i will be waiting for the solo x. if the problem still appear, possibly new gear. but you're right. maybe something bad in the install.
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
3K
ok so i realized the one u gave in the example did the same video stuff so i see the one mentions 13 band equalizer but the other has "higher"...
17
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
564
6
499
WinC101
WinC101
Bonaire
WinC101
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
