Speakers have noise with new head unit
  • 1
hutt132
US
I installed a JVC KW-V20BT head unit in my 2006 Acura TL. The car has a factory amplifier that does not use RCA and I hooked the remote turn on for it to the head unit, as well as all the speaker and power wires.
The first time I turned the head unit on, I do not remember hearing any noise, and I played a song with it fine. There may have been noise, but I can't accurately remember. I then powered it down and secured the wires. I powered it back up again and I now notice noise playing through all the speakers with 0 volume and no music playing. When I turn the volume all the way up the noise gets a bit louder.
I tried plugging in/unplugging the antenna, and there are no RCA cables going into the head unit. I wiggled the wires around a bit to see if maybe a wire was picking up some noise from a power wire. The noise only starts once the head unit fully turns on. There is still noise with the car's engine off.
Could this be because the speaker wires from the head unit are already amplified by the head unit and then sent to the factory amplifier? Could I wire the speaker wires, the ones that go to the factory amplifier, to RCA plugs and plug them into the RCAs on the head unit to get rid of the noise?
EDIT: I ended up wiring the wires to RCA cables and plugged those into the head unit. The noise is still there, but vastly reduced.
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
4
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
134
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
164
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
350
hutt132
hutt132
US
hutt132
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
