Speakers and Sub stopped working
  • 3
Tyler2118
Hey guys, this is my first post on this site and I'm hoping one of yall can help me out here!
Here is my current setup I'm working with:
2009 GMC Sierra
Door Speakers - Focal Integration ISC 165
Amp for Door Speakers - MTX THUNDER75.4
Subwoofer - Rockford Fosgate P3D4-12
Amp for sub - Rockford Fosgate R1200-1D
JVC touch screen head unit
Everything had worked together nicely, except that FM radio was very spotty. I tried to fix that problem the other day, but ended up with more problems. I had reconnected the large fm radio wire with no success. I also ended up ruining the sound coming from my speakers, and also my sub. The subwoofer barely hits and has just an overall bad sound. Same thing for the speakers. I have checked every wire coming from the head unit, and nothing was disconnected when I tried correcting the FM radio. I have also checked all connections with the 2 amps, and nothing seems to be wrong. It has to be something with the head unit, but I'm just not sure what it could be. Any help would be appreciated.
Yeah, I have checked every connection and ground. The sound just isn't as crisp as it was before. The sub barely hits, and when it does, its very poor bass. I've just gotta be missing something obvious.
Did you wire your sub parallel, down to 1 ohm? I believe that amp is 1 ohm stable. Also, make sure it isn't out of phase.
How's your electrical?
Did your alt go out...because that's the key item when powering anything audio. If that don't work, neither will your amps.
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
604
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
You can use two front channels to power the full range speakers, then use the rear channels to power a sub. IMO, for that price I would rather use...
Tyler2118
Tyler2118
Dallas, TX
Boomin_tahoe
