Speaker wire disconnects
knotdrummer88
I have a 1998 jeep cherokee, and when the weather breaks in a couple months I will be making my front doors removable. Now in my front doors I have 2 mids and one super tweeter in each door. From the doors I have one run for the tweets and one run for for the mids. Now, when I remove my doors what is a good way to make plugs for the speaker wire?
I have a 98 cherokee as well. Are you using the stock speaker location?
Well, they're in the stock location in the sense that they're in the door. They are in fiberglass pods, and I also have two of the same sized mids built into the sound bar
If you have a passive x-over connected to the speakers from a single source you'd have to place dummy resistors in place of the speakers if you're going to use your system.
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
971
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
knotdrummer88
knotdrummer88
Toledo, OH
whitedragon551
