Speaker help (troubleshooting)
  • 3
thai_creeper
Still having the problem of my left front speaker not working (rear speakers and front right speaker works fine).
I'm not too familiar with how to tell if a speaker's broken so I went ahead and took off both doors and swapped speakers and the right works and the left doesn't as before, so now that I know it's not the speakers what would you guys check next?
Don't know if this is stupid cuz I'm not too familiar with this stuff, but the next thign that came to mind was rewiring the HU so it outputs the left to the right and the right to the left. Is this just going through too much trouble? What should I try next?
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
457
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
6
827
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
thai_creeper
thai_creeper
bay area, ca
thai_creeper
