Soundstream XXX-15000D 6,400W, XXX-Series Class D Monoblock Amplifier- nice !!
  • 6
davidtemple
Caraudio Guru
uSED 9/10 ONLY INSTALLED AND PLAYED FOR FEW HOURS...
$1800 PLUS Shipping
16,400W, XXX-Series Class D Monoblock Amplifier
Soundstream XXX Series Monoblock Class D Car Amplifier
RMS Power Rating @ 14.4 Volts:
* * 5 ohms: 7400 watts x each chan.
* * 1 ohm: 4616 watts x each chan.
* * Bridged, 2 ohms: 9360 watts x 1 chan.
* * Bridged, 1 ohm: 14,800 watts x 1 chan.
RMS Power Rating @ 16 Volts:
* * 5 ohms: 8200 watts x each chan.
* * 1 ohm: 5125 watts x each chan.
* * Bridged, 2 ohms: 10,400 watts x 1 chan.
* * Bridged, 1 ohm: 16,400 watts x 1 chan.
All "N" channel unregulated MOSFET power supply
Dash mount bass remote included
LED power indicators
Bass Boost (40-120 Hz, 0-18dB)
Twin stack technology (strap amps together for double power)
Class D Topology
Monoblock operation
Gunmetal finish w/ brushed accents
140 Volt rails for insane amounts of power
Three-way protection circuitry (thermal, short, impedance)
Monster solid copper buss bars to pass >100 amps of current
Idle current draws 8 amps
Maximum current draws >1400 amps
Separated PWM circuitry to eliminate noise
2.5mm Thick PCB
Includes plexiglass and metal bottoms
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Silver-plated RCA level inputs
Silver-plated screw terminals
Variable low-pass filter (40-275 Hz, 24 dB/octave)
Subsonic Filter (15-50 Hz, 12 dB/octave)
Frequency response: 15-275 Hz
Dimensions: 32-11/16"L x 12-5/8"W x 2-3/4"H
Pics coming soon., I got to get better pics and i Have a show to do in Tennessee this weekend, so I'm working on them.....
owning this amp squarely puts you in the big hairy ballsack to infinity and beyond club:eek:
fwiw - I have two XXX6500D's and have had two XXX4000D's and this single one drops bombs on your moms with them... great amp. great review.
$1800 PLUS Shipping
Class D Topology
Monoblock operation
2.5mm Thick PCB
What other amps do you have for sale if any?
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
serjr711.
