Soundstream Rub1.2500
k3n12ock
MD/CNY
Soundstream Rubicon Series Monoblock Class D Car Amplifier
RMS power Rating:
4 ohms: 1000 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2500 watts x 1 chan.
MOSFET power supply
Remote gain control included
Midnight blue finish w/ brushed accents
LED protection indicator will be illuminated when the amp has gone into a self preservation mode
Twin Stack Technology TM (strap amps together for double power)
Tri-Mode Capable
Three-Way Protection Circuitry (Thermal, Short, Impedance)
SMT built in cooling fan
Monoblock channel operation
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated rca level inputs
Chrome-plated screw terminals
Variable low-pass filter (50-150 Hz @ 12dB)
Subsonic Filter (10-40 Hz @ 12dB)
Bass Boost: 0-18 dB @ 45 Hz
Damping factor: >250
Signal-to-noise ratio: 105 dB
THD (Total harmonic distortion): 0.5%
Frequency response: 15-150 Hz
Dimensions: 22-13/16"L x 8"W x 2-3/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
1-year Manufacturer's warranty
Works. 7/10 Cosmetic for some small scratches and marks and some major ones near the speaker terminals. I give it a 9.5/10 mechanical and here's why; both fans are loud and although if you knew how to replace them, should probably do so. If not, shouldn't matter. The amp does get hot and will cut off. It's happened to me twice. However, when I took the back plate off and bumped, it got warm but never cut off. I drove 6 hours from MD to NY bumping LOUD on and off and it didn't cut out at all, same with the drive back. I have since put the back plate back on and although it got hot, has not cut out on me since. It still works 100%.
$185 shipped firm
USPS or FedEx
Trade you a skar zvx-15 not 5 months old still has shiny copper coil. And it would be ready to ship tomorrow. It's worth 150 more than a rub2500 id trade straight up.
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
5K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
k3n12ock
k3n12ock
MD/CNY
southport2014
