Sound stream human reign
  • 5
ray60218
Sound stream human reign hru.4
Open to all trades
RMS Power Rating:
4 ohms: 140 watts x 4 chan.
2 ohms: 240 watts x 4 chan.
Bridged, 4 ohms: 480 watts x 2 chan.
MOSFET power supply
LED power and protection indicators
Hawkins Bass Boost (0-9 dB @ 70 Hz)
STACT (Stabilized Apex Current Technology) reduces power supply stress by 50%
4-Channel operation
IDI (Intelligent Distress Indicator) provides visual indication of amplifier protection status
RUBI (Rapid-Use Branched Impulse) proprietary power supply technology
Preamp RCA outputs
Harmonic bass alignment for a cleaner and sharp bass equalization
Triple darlington output circuitry
Drive delay II eliminates turn on/off pops
4-Way protection circuitry (DC, thermal, short, and impedance)
Selectable balanced inputs for enhanced level of noise reduction
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (40-160 Hz, 24 dB/octave)
Subsonic Filter (13-30 Hz, 12 dB/octave)
Frequency response: 10-40,000 Hz
THD (Total Harmonic Distortion): 0.005%
Signal-to-noise ratio: 105dB
Dimensions: 22-1/8"L x 11-1/8"W x 2-3/4H
4-gauge power and ground wiring is required for installation.
That xenon is about the same size. I already have another 4 channel smaller footprint
Looking for a good 15 maybe some 8's or a good mono amp I can add cash depending on the trade
Sound stream human reign hru.4Open to all trades
RMS Power Rating:
MOSFET power supply
4-Channel operation
Preamp RCA outputs
Did you get rid of the amp //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
ray60218
ray60218
Phoenix,AZ
Louisiana_CRX
