Sound Deadening
  • 5
I was wondering if sound deadening is worth the money. If so, where can I get some for a 1999 4runner and where do I apply it?
get your system in, play it full blast, narrow down the problem areas and buy the amount needed. You mainly only want to use it on big flat areas that can vibrate/flex to the point where it makes noise. You put CLD/dynamat/deadener matts on to reduce vibration and lower resonant frequencies. Less flex = less energy loss = louder. Not by a whole lot but its noticeable. You dont want to just cover up every nook and cranny, thats a waste of money. However if you plan on doing the whole car, look up stinger expert roadkill 36 square feet pack under 100 bucks and its thick and sticks pretty well.
Most other rattle problems, you should use weather strip foam, expanding foam aka great stuff(red can) and closed cell foam. Its to decouple(pad the surfaces, keep em from vibrating against eachother).
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
3K
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
3K
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Savackz
Savackz
GA
garychurch84
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
