Sony "Big Red" Mobile ES XM-7547
biglou001
Item(s) for Sale: Sony Mobile ES XM-7547
Item(s) Description/Condition: Great 4 channel SQ amp. Been sitting in a closet for some time. Took it out and cleaned it up. Powered it up today on some cheap JBL bookshelf speakers and almost decided to keep it. Man this thing sounds good. It is huge though, so if space is a problem, this amp is not for you.
Specs from Crutchfield
Performance
RMS Power Output (Watts x Channels) 75 x 4
Peak Power Output (Watts x Channels) 180 x 4
Power at 2 Ohms (Watts x Channels) 150 x 4
Bridged Power (Watts x Channels) 360 x 2
Minimum Impedance Bridged 1
Minimum Impedance Unbridged 0.5
Best Frequency Response 5-100k Hz
THD at Rated RMS Power 0.04%
Signal to Noise Ratio N/A
Input Voltage 14.4v
Features
Amplifier Class AB
Low-Pass Crossover Frequency 50-400/500-4k
Low-Pass Slope (dB/octave) 12 dB
High-Pass Crossover Frequency 50-400/500-4k
High-Pass Slope (dB/octave) 12 dB
Bass Boost 0-10 dB
Bass Boost Frequency 40 Hz
Fan Cooled No
Fuse Rating 25 x 4
Speaker Level Inputs No
Preamp Outputs No
Width (inches) 21-1/8
Height (inches) 3-5/16
Depth (inches)
non-negative feedback design for superior reproduction
high-voltage/high-current modes
single-ended push/pull design for stability at 1 and 0.5 ohm
discrete differential inputs for reduced noise
dual power supplies
MOSFET output power supply
high current MOSFET finals
selectable low-cut (subsonic filter) 7Hz-40 Hz with selectable cut and boost (0-10 dB)
103 dB signal to noise ratio
3-way protection circuits
heavy-duty connectors with brushed aluminum cover panel
150 watts x 4 or 360 watts x 2 into 1 ohm
continuously variable high-pass and low-pass crossovers (50-4,000 Hz, 12 dB/octave)
40-amp fuse
21"W x 3-5/16"H x 12"D
Price: $250 shipped
Shipping and Miscellaneous Item Information: I pay shipping
875
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
991
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
biglou001
biglou001
Wasilla, AK
mr b
