Tony95bagged
What would be the best amp(s) on a $400 setup with out overloading an amp(s)?
you'll get about 2k rms maybe tops out of those amps. just save more and buy a better bigger amp. that will be your best bet. unless you want an AP3KI found 2 bamf 4000d was thinking of running I'n series at 4000+ rms but probably overrated by a 1000 but both new at $380 shipped.
well in order to get a good amount of power you'll need some bigger better batts then those optimas. also what kind of power are you trying to throw at it? or what do you want to throw at it?It will. I'll be running 2 of the largest deep cycle optimas cap 200+ alt all 0ga. I just need to know what amp is a good bet on the solo x so i can figure the amps my truck needs to hold Atleast 12volts.
then your best bet right now would be something like a saz2500 if you can find one in your range. probably be used but itll work.Probably a true 2500-2700 rms
originally was going to say a rubi2500, didnt think of the hifonics amp at all or the AQthe cheapest options for a good amplifier, that I know of. AQ2200D Amplifier
WoofersEtc.com - RUB1.2500D - Soundstream Monoblock 2500 Watt RMS Rubicon Series Subwoofer Amplifier
WoofersEtc.com - BRZ2400.1D - Hifonics 2400W RMS, Brutus Series 1-Channel Monoblock Super Class D Amplifier
