Snap Crackle Pop! Smoke. Help with deck!!!!
  • 1
rocca_dogg
More ThUmP in the Trunk
Ok here's the deal. I wired in the 12v wire and acc wire to my car and had it all hooked up to my deck. Well the last thing i connected was my ground. When I found a good piece of metal I touched the ground to it, it sparked violently and then my head unit started smoking! What the hell did I do? Did I just kill my new deck.!!!!!! Did I just blow a fuse??? What does a blown fuse looki like!
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
4
982
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
965
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to...
rocca_dogg
rocca_dogg
Coeur d' Alene
rocca_dogg
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
