SK-1500.1 strapped output @ 4 ohms?
  • 3
why would you strap @4 ohms each amp will be running @2 ohms sp id say 16-1700 between the 2
I can only load 1 or 4ohms being a D2. I dont want to risk having space heaters by running 1ohm
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
362
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
600
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
9
995
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
857
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
JoeK
JoeK
Ringtown, PA
BrownVanMan
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
