Should I buy this ID Max 12"?
eddie_93
Colorado
This Image Dynamics Max 12" is listed locally for $125. I want to pick it up but from what I see in the pics I think the coil looks pretty dark so that has me a little worried. The guy is 40 minutes away from me so I wanted to see what everyone here thought about it before I went to check it out. Let me know what you think!
Also, anyone happen to know what version of the ID MAX this is?
**** is that a quad stack motor? If so it's well worth the cost especially if its a 3" coil or bigger.
Or is it a big *** triple stack either way it's a nice moofer but that coil does seem a little dark and used,.. probably not much life left in it.
I think i read it's a triple stack but not positive. I also say some people say the coil discoloration is normal for this sub but im not sure if thats true or not, can anyone confirm?
All these older IDMax's look like that. I think that's about 3 versions ago but I'm not an ID guy so not too sure. I'd say try and talk him down to 100 bucks or so. Have you heard it? Take a dmm and check the coils to make sure they read out right and go for it. They're nice woofers... If anything play it for awhile and build something custom later on with the motor.
//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Looks like a v2 based off the motor. Some v3 were still triple slug motors though, iirc.
Coil is usually darker on idmax, I'm roo lazy to pull mine and confirm. I could be confused with my spg555.
**** good price, especially if coils read out good
its a v3. i worked at ID building these i would not get it due to whom i know built that driver. look at the leads on the spider, it will tear at higher excursion. the triple stack was due to an ordering problem on the larger slugs and ID had a oh crap moment and built a run of them using triple slugs. if it doesn't work talk him down ALOT and buy a re-cone kit for it
I have not heard it but he claims it works great. It's listed on my local craigslist but the owner lives about 40 mins away. Was planning on taking a dmm and checking the coils if you guys think it's worth the trip and the dark color of the coil isn't much too worry about.
I know I can get him down on price as well. Thanks everyone for your advice //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif this will replace my SA12 if it works well
Have you check to see if the prefab would fit...
13
The CT's are nice, That Sundown is a a frik'n beast!
935
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
764
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
891
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
eddie_93
eddie_93
Colorado
eddie_93
