Setting the Gain on the Amp
  • 3
Im having hard troubles setting my Gain on my Amp. I have a 3000 watt amp and having my subs on a 2ohm load and i know thats all the information you need to set the gain using the formula with sqrt which i forgot :/ but i was trying to set up my gain, i watched a few youtube videos and i first turned down all the gain, subsonic, etc besides the lowpass which i put up all the way, so i unplugged my speaker wires and turned my radio all the way up and put the volt meter across the speakers, i have no reading on the voltemeter and i have the voltmeter to read ac, and i have song playing, so what am i doing wrong?
it was that planet audio 3000 watt amp that you didn't like //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
not sure why this matters?
I'll give you a little education. Setting the gain using a DMM you set it to the RMS of the amp. If its a overrated amp and you set itto what it says you will clip it to death. The DMM method is not good for those amps cause you have no idea what to calculate
well its that planet audio 3000 watt amp
Big fail
If its a 2ohm amp yes
ok so here is my original help: i first turned down all the gain, subsonic, etc besides the lowpass which i put up all the way, so i unplugged my speaker wires and turned my radio all the way up and put the volt meter across the speakers, i have no reading on the voltemeter and i have the voltmeter to read ac, and i have song playing, so what am i doing wrong?
Chief612
Chief612
Mpls, Mn
Chief612
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
