second guessing my sub box
I recently built a box for my boston G3 10 I built it to the manufactures specs and built a amp rack on the side. Now what I started thinking is with the amp rack attched will the vibration from the sub mess with the amp ? the sub will be pusshing 350 rms max.
lol 350 rms max
No, it will be fine. Guys run amps with 10x that power and don't have problems. If your really worried about it, you can get some rubber insulation or mounting feet and put it under the amp but if I were you, I wouldn't worry about it.
Thanks that's what I was thinking .Just wanted advice from more experienced people. as far as lol 350 max this is being set up for SQ not rattling windows I like to hear all of the music not gust the bass.
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
8K
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So you have an 800 watt sub (1600 ios a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
7
81
ricktcole
ricktcole
Elizabeyh City,NC
mazdakid
Dylan27
    May 19, 2024
Dylan27
    May 18, 2024
