Running Two JL 10W6's At 4 Ohms Help...
darita
My installer tells me that if I run my two JL 10W6V2's at 1 ohm, I run the risk of dammage to my system if I make the mistake of accidentally cranking the volume. He strongly suggests, since I don't listen at high volumes to begin with, that the JL's be hooked up at 4 ohms to my AQ1200D amp. Doing so, he says, will give around 500W from the amp, to the two JL's.
Is there any validity to what he is saying? Keep in mind I do not compete and I am an average listener who doesn't need to rattle the bolts loose in my trunk. Before you ask, I got the JL's and AQ amp because I wanted quality gear, producing quality bass.
JL 10w6v2 D4
Free Air Resonance (Fs): 28.5 Hz
Electrical “Q” (Qes): 0.497
Mechanical “Q” (Qms): 8.458
Total Speaker “Q” (Qts): 0.469
Equivalent Compliance (Vas): 1.18 cu. ft. / 33.4 liters
One-Way, Linear Excursion (Xmax)*: 0.60 in. / 15.2 mm
Reference Efficiency (no): 0.149%
Efficiency (1W/1m)**: 83.7 dB SPL
Effective Piston Area (Sd): 51.4 sq. in. / 0.0332 sq. m.
DC Resistance (Re): 6.30 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 600W
Driver Displacement: 0.068 cu. ft. / 1.9 liters
Net Weight: 14.4 lbs. / 6.4 kg
AQ 1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V—16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
tell him to **** off and run @ 1 ohm
So there's no validity to anything he is saying? At the time we spoke it made some sense to me that if we ran the amp at 1/2 it's max output, then even if speaker shorted, there wouldn't be a danger of frying anything. He said with my listening habbits, I probably wouldn't be pushing the amp anywhere near 500W anyways. Can someone please explain why this isn't the case so that I can understand it and relate it to him?
If you realy don't think you'll want the extra output that you'll gain by going from 500 watts to 1200 (4db's so somewhat significant, with power compression I bet it's only 3dbs' tho) then running it at 4 ohms isn't a terrible idea. It will be easier on the amps and the sub. I'd try it at 4 ohms and if you end up turning your gains up pretty high or find the sub isn't loud enough, rewire it. If your really not into alot of extra bass then running it at 4 ohms may make level matching a bit easier anyway. However, you probably could have simply bought a smaller amp, although I do think those AQ's were on sale for a good price IIRC...
lol the guy was trying to save your subwoofers from blowing. Your equipment isn't the other peoples on the forum. I don't really know why the hell he would say to run them at 4 for in case you turned up your volume? He sounds like an idiot there, but you have to remember that Ohms is resistance. The less resistance you have to your subs, the louder they will play and the more distorted they will get ending up usually blowing. running your subs at 4 ohms will save them tremendously but will sacrifice some power. Plus you always need to break in your subs for about a week. So the guy kinda knew what he was talking about i guess, but I'd still call him an idiot, but thats just me. And hell if you want loud go loud and run them at 1 ohm
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
670
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
darita
darita
Sacramento
cebbeler7
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
