Running system in a diesil
Well honestly, there's nothing in this thread that has anything to do with your question. Not sure if you posted in the correct thread, or let it scroll down to far, and ended up in a different thread.
If you are putting two batteries in, and they are not on an isolator put it on the second battery, the one that's not to the starter.
This thread does have something to do with my question since it is a diesel install. Diesels already have two batteries. I was asking which battery he used.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
681
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
PESteele
I wang on an 8 in a van
PESteele
annapolis
HardofWhoring
Decebal
    Jun 10, 2024
