running subs from a cd player
Umm I guess if you want to send your subs 15watts //content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
You will probly end up severly clipping your amp wanting more power which it can give you. I'd wait for a real amp, but I guess you *could* do it.
On some Pioneers you can bridge the rear channels to a sub and run something like... 30 watts... (DEH-P760MP says 70x1 max)
I still don't think it would be worth it, but it might be OK with a really efficient sub.
well i did it, and for some reason my subs sound awesome. better then some systems i have heard with an amp. its good enough for a couple of weeks untill i get an amp.. no one has really answered my question, will it hurt/ruin anything....speakers/subs/HU.........
As long as you don't clip the hell out of the HU's internal amp, I don't see why it would hurt anything.
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
707
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Burtonrida19
Burtonrida19
Maine
Norcalracer283
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
