running 1 ohm on 2 ohm stable amp
  • 3
loudenuff
WA gwon?
I will not be able to afford an ho alternator in the near future so I'm just gonna stick to my small kicker cx600.1 amp. I'm getting two low-level do share 12s, was looking to get the r2s but I can only find them in dual 4. I played my 15 at 1 ohm on the amp and it didn't sound too shabby, nor did it get hot so is this okay? or do you think it'll be a case of spontaneous combustion in a month or 2
some Kicker amps will play at 1Ω with no issues, some will through a temper tantrum. if you have the electrical and the amp doesn't have a hissy fit than keep on.
Well, its kind of like playing Russian Roulette. It MAY work, until one day, yes, poof.
I have accidentally demo'd many many amps to people prior to sale, and always would forget to rewire the woofer I was using (i always run at 1Ω or less) and 90 % of the time, the amp would play for a minute or two the either shut off or go into protect.
Its not a good idea. But hey, do what you want.
Or, you sell that amp, go without bass for a bit (I know, terrible) , then put that cash towards the amp that fits.
Thats how I moved up in car audio, started with a sony xplod "1000 watt amp" and a dumpy JL W0, now, i have so much gear I have no room for anything else in my bedroom.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
671
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
loudenuff
loudenuff
WA gwon?
FML
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
