Rolled down my window in the drive thru and my front left speaker stopped working.
  • 3
zanenienow
CarAudio.com Newbie
Yesterday night I finished up putting my new sound system in my car. I was playing with it to find my sweet spot this morning and I went to get some food and as I rolled my window down to order, my speakers just suddenly stopped. I was wondering if I just nicked the wires or should I be more concerned? I don't think it's my amp though because this only happened after I rolled down my window.
Most likely shorted out the amplifier output and it is now in protect... or worse, blew something. Pull all the wires off the terminals and test with a different driver.
If it has no output, you may need to have it serviced, but if all is fine, youll need to pull your door back apart to find a more than likely short and extend the wireing to clear underneath the window sash.
I did this in my truck once. Thinking with my butthole when running wires up through the door to the grommet, and shorted them out rolling the window down. Dumbest ******* mistake I ever made, other than the time I hooked up a head unit when I was 15 without unhooking the battery.
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
818
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
853
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
12
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
zanenienow
CarAudio.com Newbie
zanenienow
Richfield WI
SlugButter
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
