hispls
I'm so ******* sick of people misusing this term. I'll just leave this here:
Root mean square - Wikipedia, the free encyclopedia
Nope. OP is right - "RMS" is not a unit of measure. What you described is RMS WATTS. You can measure RMS VOLTS, RMS AMPS, etc. But just "RMS" has no meaning.(RMS) is the value of a periodic current is the DC voltage that delivers the same average power to a resistor as the periodic current.average power.
square root of the arithmetic mean of the squares of a set of values, used as a measure of the typical magnitude of a set of numbers, regardless of their sign.Nope. OP is right - "RMS" is not a unit of measure. What you described is RMS WATTS. You can measure RMS VOLTS, RMS AMPS, etc. But just "RMS" has no meaning.
Now don't get me started on "dB"
Funky Pup? fyiSo, what RMS do I need to hit 150dB's?
A "measure" and a "unit of measurement" are not the same thing. Break out that oxford again. Nobody said "RMS" wasn't a measure of something. We said it is not a "unit of measurement". "Dollar" is a unit of measurement. "Volt" is a unit of measurement. "Foot" is a unit of measurement. RMS is a method of averaging typically used in physics, statistics and engineering. It is not a unit of measurement.Funky Pup? fyiAsk the writers and editors of the Oxford English Dictionary I guess? Considering they say it IS indeed a unit of measurement.
I get the first part. But I guess I don't understand how dB isn't a unit of measurement still... would it not be considered a measurement vs a reference level? I only ask because when I reference my electrical measurement tables dB is definitely one of them listed.A "measure" and a "unit of measurement" are not the same thing. Break out that oxford again. Nobody said "RMS" wasn't a measure of something. We said it is not a "unit of measurement". "Dollar" is a unit of measurement. "Volt" is a unit of measurement. "Foot" is a unit of measurement. RMS is a method of averaging typically used in physics, statistics and engineering. It is not a unit of measurement.
dB is also not a unit of measurement. it is a logarithmic expression of a ratio of two numbers and is unit less. dBV (dB relative to one volt), dBmW (dB relative to one milliwatt), etc. are units of measurement. The "dB" we typically use to measure SPL is technically "dB relative to 20 micropascals", which is roughly the quietest sound the human ear can detect.
Although this is true, dB is still properly used as a unit of SPL.A "measure" and a "unit of measurement" are not the same thing. Break out that oxford again. Nobody said "RMS" wasn't a measure of something. We said it is not a "unit of measurement". "Dollar" is a unit of measurement. "Volt" is a unit of measurement. "Foot" is a unit of measurement. RMS is a method of averaging typically used in physics, statistics and engineering. It is not a unit of measurement.
It's pure ignorance and looks ignorant when people write it. People who use the term think that an RMS is something that should be compared to some "peak" number which is and has always been pure marketing ******** and was never actually the peak to peak of the waveform, but simply a wishful thinking number that you may or may not be able to measure for one second before you see smoke.If someone mentions that there sub does 500 rms is that so bad? You guys have been around long enough to understand this is defaulted to "500 watts rms".
Now forget my post if someone was trying to setup an equation or something with just saying rms alone and not specifying what was meant by that.
So if you're current is 10A RMS and your voltage is 10V RMS, your power would be 100W RMS^2? If the RMS is a unit of measurement it would need to be also multiplied.Funky Pup? fyi
I'm glad someone actually paid attention in school. Personally I'll let dB slide on it's own since in the context here it's implied that it's referring to sound intensity.A "measure" and a "unit of measurement" are not the same thing. Break out that oxford again. Nobody said "RMS" wasn't a measure of something. We said it is not a "unit of measurement". "Dollar" is a unit of measurement. "Volt" is a unit of measurement. "Foot" is a unit of measurement. RMS is a method of averaging typically used in physics, statistics and engineering. It is not a unit of measurement.dB is also not a unit of measurement. it is a logarithmic expression of a ratio of two numbers and is unit less. dBV (dB relative to one volt), dBmW (dB relative to one milliwatt), etc. are units of measurement. The "dB" we typically use to measure SPL is technically "dB relative to 20 micropascals", which is roughly the quietest sound the human ear can detect.
I think you mean the other way around. Agreed, and I'll take that a step farther and say I'd really like to see SPEAKER manufacturers add some time numbers as well. In both cases I think most people who purchase based solely on whoever puts the biggest number on the box would be rather shocked.\it annoys me when amplifier manufacturers don't rate power output noting the load, THD, and supply voltage. i'd also like to see time. 1000W for 1 second is much more difficult to achieve than for 1 hour (all else equal). thermal management and long-term current handling costs money in R&D and construction.
I couldn't agree with this any more. So many manufacturers care more about marketing than the usefulness of specifications they publish.I think you mean the other way around. Agreed, and I'll take that a step farther and say I'd really like to see SPEAKER manufacturers add some time numbers as well. In both cases I think most people who purchase based solely on whoever puts the biggest number on the box would be rather shocked.
