RF Punch P2D4 or Pioneer TS-W3003D4?
  • 2
WhisperThang
Looking to upgrade 2 10" original JL Audo W3's to some of these 12" sub. I'm looking to spend around 100ish on each sub. I saw both of these subs but am not sure which is better. I listen to mostly hip hop and want hard hitting bass but don't want hella hella distortion. Which do you guys think is better?
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
5
914
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
509
WhisperThang
WhisperThang
Stockton, CA
bebitte3o
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
