Replacing front speakers in 1999 Saturn SL
  • 2
yep.
lol. i got a 2001 SL2. - click on my signature image for somthing you will like -
anyway.
there should be about 5 screws around the door and behind the door handle maybe.
then there is the manual window (if not disregard this)
the roller has a little C clip around the base, get a flathead screwdriver, push the door panel in, and look in there with a flashlight (right at the base) there is a shaft. and around that shaft is a C clip. rotate the window roller until you see the opening in the ring, and push both sides off the shaft. make sure you dont loose the **** thing. they are quite small and have lots of pressure when they decide to un-clip.
then, remove the window roller (keep all screws and parts together) and then proceed to pull OUT and UP on the door. and it should slide off.
i believe they are 5.25's back there. hopefully that helps ya //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
At the end I decided to take the dashboard out, since I also had to solve a problem with the heater core. Upon inspection, I could not find any...
10
Alphafrog1
PURDUE!!!!
Alphafrog1
Cincinnati, Ohio
req
