Remote turn on wire
  • 5
Dumb question, is the remote amp wire a constant 12v? I was under the impression that is wasn't.
It's a very low amperage 12v signal. The voltage just has to be high enough to be able to tell the device that it's connected to to turn on. If the remote wire dips too low or has no voltage, it turns off the device that it's connected to.
The voltage for something like amp turn on (remote wire) can come from any source you want it to. Like I say, if your remote wire isn't constant, then that's a problem, and your amp would turn off. You can measure these voltages with a volt meter or fluke or any DC voltage measuring device.
I had to tap into my cigarette lighter for my remote turn on. For some reason my Jeep had a 5 volt switched connection instead of a 12 volt from the stock stereo, causing a nasty pop when i turned off the vehicle. If the cigarette lighter stayed on constant with the key off, it wouldn’t have worked.
You can use a relay to create a soft turn on.
You can connect the amplifier remote turn on to the red 12v accessory wire that turns on the stereo when you turn on the key. The amplifier will...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
770
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
marscounty
CarAudio.com Newbie
marscounty
canada
Kickstand
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
