Remote turn on wire location
  • 2
Which loc are you using? Most new ones are automatically turning on and have an rem out to use. If not, use the car’s ACC that turns on with the key. If you experience “thumps,“ you may need a replay to isolate the 12v source.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
711
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
JustinStone
aspiring nutrient
JustinStone
Florida
Scott2021
