remote transmitter programing
  • 3
That is the standard configuration... so resetting it isn't going to do anything.
I have 2 of these remotes and on my car it works with just pressing the start button once not twice as with the transmitter to my wife`s car,just would like it to fuction as my does.
its a programming feature. whoever intalled it set it to be 1 press, because default is 2. You'd need to get into the programming menu to change it..
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
706
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
jrouter76
jrouter76
jrouter76
Mount Vernon ,Illinois
jrouter76
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
