Regular cab '94 Ranger bo design help please...
  • 1
Chollis
I have a little 1994 ford ranger regular cab that I use for work. I want to build a custom enclosure for behind the seats, but I really need help with the design. I have 2 Audiobahn AW1000q subs that I would like to put in the enclosure.
Here are the specs on the subs:
Size 10 -inch
Impedance 4 ohms
Cone Material Non-pressed pulp
Surround Material Foam
Ideal Sealed Box Volume (cubic feet) N/A
Ideal Ported Box Volume (cubic feet) 1.632
Port diameter (inches) 3
Port length (inches) 8
Free-Air No
Dual Voice Coil Yes
Sensitivity 91.1 dB at 1 watt
Frequency Response 23 - 500 Hz
RMS Power Range (Watts) 50-600
Peak Power Handling (Watts) 1200
Top Mount Depth (inches) 5 1/4
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 9 5/16
Vas (liters) 29
Fs (Hz) 30
Qts 0.41
Xmax (millimeters) 12
I have bucket seats with no center console and I am tall, so I would like to have the subs mounted close to each other so that I don't have to have one of them behind my seat. Rarely does anyone ride in the passenger seat so I can pull it forward as much as I want. I was thinking that I would like to mount them close to each other behind the passenger seat area and have one port facing the driver's side. I want it to be as loud as possible too.
I know that there are a lot of posts about single cab truck enclosures, and believe me I did read probably all of them. I didn't find the answers I was looking for, so hopefully you guys will help me out... I got the subs for free from a friend so I figured I'd use them. I am open to suggestions though, and I have a used Kicker SX900.2 that is fully functional that I would trade for some higher end subs. Thanks a bunch everybody.
Sorry, here are the recommended enclosure specs:
Recommended Sealed Box Volume: Audiobahn recommends a sealed enclosure with an internal volume of 0.4 cu/ft to 0.95 cu/ft.
Recommended Ported Box Volume: Audiobahn recommends a ported enclosure with an internal volume of 1.632 cu/ft and one 3" diameter x 8" long port.
I also forgot to mention that I think I would like them to be firing down. Thanks guys.
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
Chollis
Chollis
Los Angeles
Chollis
