refurbished DB DRIVE PD2000.1
Jason19
1. Product: refurbished DB DRIVE PD2000.1 2000 Watt RMS Platinum Series Class D Monoblock Amplifier
2. Specs:
RMS Power Handling: 500 watts x 1 chan. @ 4 ohms
RMS Power Handling: 1000 watts x 1 chan. @ 2 ohms
RMS Power Handling: 2000 watts x 1 chan. @ 1 ohms
Input sensitivity: 250mV-6V (Low level)
Variable high-pass filter (10-50 Hz, 24 dB/octave)
Variable low-pass filter (50-250 Hz, 18 dB/octave)
Subsonic filter (20-50 Hz @ 24 dB)
Phase Shift: 0-180°
Signal-to-Noise Ratio: >90 dB
THD (Total Harmonic Distortion): Input Voltage: 10V-16V
Jack for Remote Control: Yes
Remote Control Included: Yes
Power Fuse: 2 x 80A
Bass Eq: 0-12dB @ 45Hz
Frequency response: 10-250 Hz
Dimensions: 10-1/4"L x 23"W x 2-1/4"H
Weight: 25 lbs
3. Description/Condition: The amp is refurbished so it has been repaied and works perfectly. The amp itself is in very good condition it comes with a 200 amp fuse and fuse holder and also a remote bass knob.
4. Price: : 200 shipped
5. Pictures:
Monster 2k amp here guys. Actually does about 2500 @ 1 ohm, & 3k or so @ .5 ohm with good electrical. The amp should have been put out as a 2500rms amp lol. GLWS OP...
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
Jason19
Jason19
Kenosha Wisconson
Jason19
    Jun 3, 2024
