Reducing port size after final construction?
creyc
I'm trying to reduce the frequency of a circular port in my sub, to extend my low frequency capbilities. It's currently 6-7/8" and I'll need to take it down to 4-7/8" to get the change I'm looking for. Is there an easy way to do this without major work?
The port is 15" long, the other option I have is to extend this to 32", which is longer than the whole box. How should I go about re-tuning this port?
can you use a 90 degree bend and add to the port.
It's usually pretty hard to do this after the box is already built. You could go to home depot, get some of the small sonotube they have for concrete forms though and make a sleeve to go inside with a few layers. You can cut it length wise on one side and pull the diameter down to fit as you need it.
Otherwise you could make a plate to screw over the port with a smaller diameter tube in it. Just stick it right into the other one essentially. That way you could unscrew it to get higher tuning and more SPL.
I usually design SPL boxes with multiple ports. That way you can tune high, say 50hz for SPL comp, then plug 2 of 3 ports and be tuned down much lower for everyday use.
John
John
Great idea with the plate/tubes. I might have to do just that.
The sub in question is a pre-fabricated kicker box with two 10" L5s. They tune it high to get a nice loud peak around 64Hz, at the expense of a 38Hz F3, a bit high for my tastes. With this port change I should see a flatter response and a lower F3. Taking cabin gain into consideration only magnifies both of these effects.
Please look around on the Impala forums and see if they cracked the voltage control. My 13 Silverado was really simple and only required a quick t...
17
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
866
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
creyc
creyc
Los Angeles, CA
creyc
