Rear speakers not working help
  • 2
mcpmies
CarAudio.com Newbie
I recently bought a 2007 Ford Edge SE, with 4 factory installed speakers and a basic AM/FM/CD radio. The rear speakers are not working. I switched them with the front speakers and they worked, and I attached a 9volt battery to the harness and sent a signal to the rear speakers and that worked. I swapped out the radio with a used unit to no avail. When I press 3 and 6 on the presets to run a self test, it only tests the front speakers, leading me to think there is a setting in the radio that I can change to allow it to recognize the rear speakers. There is supposed to be a fade control, but it is not in the menu, leading me to think it is the receiver, but again, i have swapped that out. Any ideas?
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
3K
I will check when I’m off work and get back with you. The current speakers are coaxial 2 way, it has the tweeter speaker in the middle. I posted a...
7
mcpmies
CarAudio.com Newbie
mcpmies
Tulsa, OK
mcpmies
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
